July 24, 2015, 13:24 |
Computing RAOS with AQWA
Rep Power: 10 |
Hi everyone,
I'm trying to compute RAOs of a FPSO using Ansys AQWA. But it seems I'm doing something wrong because the RAOs of some degrees of freedom are completely out of range (27 deg/m in roll, while 5 deg/m expected) even if the general allure of the curves are fine (with pic periods corresponding). I thougth I was doing everything right, step by step :
I'm pretty my geometry and mass/inertia distribution are okay because hydrostatics are fine. Does anyone know if AQWA's output must be dimensionalized by some factor, or if I forgot any option during calculation, or something else ? Thank you. Regards, Antoine |
July 27, 2015, 10:33 |
Rep Power: 10 |
It seems that I must define an additional damping due to viscosity. After a quick search, I read that the FIDD could suffice, but I didn't really understood how to use it. Please could someone explain it ?
Display Modes | |
problem during my computing | oliver | FLUENT | 0 | May 31, 2007 09:35 |
CFD algorithm design with reconfigurable computing | Beatríz Navarro | CFX | 4 | June 27, 2006 05:39 |
CFD algorithm design with reconfigurable computing | Beatríz Navarro | Main CFD Forum | 1 | June 25, 2006 15:25 |
CFD algorithm design with reconfigurable computing | Beatríz Navarro | Fidelity CFD | 0 | June 24, 2006 19:23 |
CFD algorithm design with reconfigurable computing | Beatríz Navarro | FLUENT | 0 | June 24, 2006 19:22 |
