August 6, 2015, 17:26 |
Slicing 2D surface in DM
Rep Power: 10 |
My goal will ultimately be to model a jet impinging onto a surface. I have a 2D surface which will represent half of the simulation. Is it possible to "slice" the surface body into various sections much like you can do in 3D? I have not found a way to divide of the surface body into parts to make meshing easier.
Thanks. |
August 6, 2015, 18:48 |
Rep Power: 14 |
Yes you can slice surface body just as you slice solid body
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[snappyHexMesh] Problem with Sanpper, surface still Rough | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 7 | November 5, 2014 12:05 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
