Home > Forums > Software User Forums > ANSYS
Dividing the shroudmesh of an impeller
Old   August 10, 2015, 08:43
Default Dividing the shroudmesh of an impeller
Christoph
Ckern is on a distinguished road
I want to simulate a compressor with casing treatments (one circumferential, and another on different positions). I create the impeller mesh with Turbogrid and the mesh for the casing treatment with Meshing or ICEM. The problem is to fit the casing treatment in CFX Pre to right position or area/plane/mesh, because the shroud has no area, which fits correctly to the casing treatment. I only can chose the whole shroud, which is not that what I want to.
Question:
Is their an option to separate the shroud into different parts in turbogrid, cfx pre, etc. that I can fit them togehter. Or do someone know a better way to handle this problem.
Thanks,
Chris
Ckern is offline   Reply With Quote
Old   August 10, 2015, 11:06
Davood
IUTDavood is on a distinguished road
Hi
By using the stp format or other format ln Catia software or Solid work software or even design modeler of Ansys, the geometry modification for meshing process will be done.
IUTDavood is offline   Reply With Quote
Old   May 8, 2018, 17:41
Ruben Bruno
rbruno is on a distinguished road
Question:
Thanks,
Chris
Hi, I´m having the same problem...Did you manage to divide the shroud from Turbogrid?
rbruno is offline   Reply With Quote
Mixing tank impeller Onicon FLUENT 1 March 24, 2015 02:43
[Help!] impeller torque calculation: pressure and viscous moments ghost82 Main CFD Forum 1 March 27, 2014 02:37
CFX - Solidworks Flow, Impeller comparison aerospace_guy_ CFX 8 March 20, 2012 22:06
Problem rose from centrifugal impeller tim_shute FloEFD, FloWorks & FloTHERM 6 January 31, 2012 20:06
Simulation of an Axial Impeller cnchilavert CFX 1 October 15, 2011 02:01
