Workbench Scripting
Hello Guys,
hope, I found the correct category for my problem: I am doing a 2way FSI with Fluent and Mechanical APDL with Workbench v160. The calculation is executed on a (linux) cluster, so I need a input-shell-file. The script actually works pretty well, except the mechanical part of it as well as a nuance of the fluent part. The point is, how can I define the number of processors for mechanical? In general, how can I adress the mechanical component in my 2Way FSI? I tried to make a journal file (that was actually the way, how I cobbled the fluent-part of the script) to record the property-changes I did in the Mechanical GUI, but the workbench-journal-record doesnot record those changes. And I did not find any possibility to change the number of processors with TUI, which I think is the reason for the error, the cluster trows. Thanks in advance for your help! Best wishes, Georg |
