March 29, 2016, 07:19 |
Advice for fluid-structure simulation
Rep Power: 10 |
Dear Ansys users,
I used to do simulations only for multiphase flow and just consider solid as a rigid solid boundary. Recently, we have a new project and need to calculate the piler's (array of pliers, microfluidics) deformation due to surface tension. I've never dealt with deformable solid. Can anyone give me some advice? We'd like to start with some commercial or open-source software. Is Ansys a good choice, which package should we use? Fluent + ? Thank you very much guys Keywords: fluid structure, coupling solvers, surface tension, incompressible flow, microfluidics, |
Simulation of high pressure diesel injector - all phases compressible with cavitation | fivos | CFX | 4 | July 30, 2015 06:48 |
Huge file sizes when Running VOF simulation | aarratia | FLUENT | 0 | May 8, 2014 12:27 |
Particle trace velocity structure in grid fire simulation | hanklord | Main CFD Forum | 0 | July 12, 2013 03:25 |
advice on wind turbine simulation? | level | CFX | 2 | June 11, 2012 04:31 |
Stirling engine simulation advice needed | Geoffrey | Main CFD Forum | 2 | December 18, 2001 02:26 |
