April 27, 2016, 23:09 |
Archimedes screw rotating turbine
Nurul
Hi all, I am working on simulation using Ansys CFX. I am a newbie in this field, so I need some suggestion from all of you.
I am doing a simulation on Archimedes screw turbine which I have to ensure that my turbine blade is rotating and half submerged in air and water. As shown in Figure 1 below, the upper part is air and bottom is water (half submerged). This simulation is in steady state In this simulation, I consider the fluid part as stationary and blade part as rotating. Both fluid part and blade part is set up as a fluid domain. 1. Should I change the blade part into immersed solid as the blade is partially immersed in water? 2. Figure 2 shows the water volume fraction of my results. Is it my result can be reliable/accepted? 3. Is it my setup is acceptable for this type of turbine simulation? Thanks in advance |
May 4, 2020, 23:07 |
Dear Nurul,
Dylan Sheneth Edirisinghe
Rep Power: 6 |
I hope you could able to simulate the ASG.
Now I am simulating the ASG, and I had several problems. I am doing using ANSYS CFX. I was very grateful if you can help me with this. |
Rotating Wind turbine rotor model step up | shiyun | CFX | 3 | November 6, 2017 10:34 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 08:16 |
Archimedes Screw Turbine | Shaun Waters | Main CFD Forum | 1 | June 27, 2015 01:57 |
Rotating Impeller | Naith | FloEFD, FloWorks & FloTHERM | 22 | November 5, 2012 08:53 |
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 03:14 |
