[Sponsors] | |||||
Maximum pressure at inlet pipe while simulating journal bearing |
Vedant
Rep Power: 12 ![]() |
Dear Friends,
I am simulation journal bearing using ansys workbench. The clearance between shaft and bearing is 400 microns. The inlet pressure is 101325 pa and outlet pressure i have assumed is 0 Pa. The operating speed is 1500 RPM. After running simulations i am getting the maximum pressure at the inlet pipe. Instead it should be at the minimum film thickness position. From plot it appears that the flow is chocked at inlet pipe. But it is not the case. The pressure contour is attached herewith. Plz help. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Pressure inlet vs outlet position, transient, time dependent pressure and gravity | silent2608 | FLUENT | 0 | February 6, 2016 11:19 |
| pipe with orifice, pressure drop declines when pipe gets longer (BC problem?) | cristopf | OpenFOAM Running, Solving & CFD | 0 | January 21, 2016 05:55 |
| Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 23:02 |
| Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
| Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
