Maximum pressure at inlet pipe while simulating journal bearing
Old   May 7, 2016, 10:20
Default Maximum pressure at inlet pipe while simulating journal bearing
Vedant
vedant123 is on a distinguished road
Dear Friends,
I am simulation journal bearing using ansys workbench.
The clearance between shaft and bearing is 400 microns. The inlet pressure is 101325 pa and outlet pressure i have assumed is 0 Pa. The operating speed is 1500 RPM. After running simulations i am getting the maximum pressure at the inlet pipe. Instead it should be at the minimum film thickness position.
From plot it appears that the flow is chocked at inlet pipe. But it is not the case.
The pressure contour is attached herewith.
Plz help.
File Type: jpg water_lubricated_bearing_validation_pressure_plot.jpg (55.9 KB, 10 views)
vedant123 is offline   Reply With Quote
Pressure inlet vs outlet position, transient, time dependent pressure and gravity silent2608 FLUENT 0 February 6, 2016 10:19
pipe with orifice, pressure drop declines when pipe gets longer (BC problem?) cristopf OpenFOAM Running, Solving & CFD 0 January 21, 2016 04:55
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
