Workbench in batch mode with parametric study (design point)
I use Ansys 17.0 on linux, in CentOS6.5 in my computer or in cluster. I need some help to run calculation in batch mode with Workbench and parametric design point.:D My problem is a performing map of a compresseur. Calculations are done with CFX and a parameters table. I don't think that is a CFX problem, but a Workbench problem. Reminder that in CFX the result file is file_001.res, and the out file is file_001.out. The run is ok"in live", and creates a DesignPoint_Log.csv which resumes all my parametric values for each design point. Each calculation follows the previous calculculation when this one ended.;). All Files.res are ok. When I try to run in batch mode (workbench -B -F files.wpbj -R Journal.wbjn) on the cluster, the run seems ok (when I have a look on CFX_001.out which is writting), but the DesignPoint_Log.csv doesn't update. As the calculation is in batch mode, I have no idea if and where I can found error message (nothing in err.log or in file_001.out, etc), as in the "message windows" in "live mode" To record the journal, I do : /file/scripting/record Journal, then I put on "Update all design points", then, File/scipting/ stop Journal, and I stop the calculation. Journal.wbjn is : # encoding: utf-8 # Release 17.0 SetScriptVersion(Version="17.0.323") designPoint1 = Parameters.GetDesignPoint(Name="1") ... designPoint42 = Parameters.GetDesignPoint(Name="42") backgroundSession1 = UpdateAllDesignPoints(DesignPoints=[designPoint1,..., designPoint42]) Save(Overwrite=True) Is my Journal.wbjn ok? I already asked Ansys Support, but no good solution has been provided. (the procedure used is ok in support computer) When I open each file_001.out for each design point X (in Files_files/dpX/CFX/CFX), only few file_001.out of the first DPs are ok. For the following dp, my calculation stopped with the message " Execution terminating: STP file found." For me, this message is written in the file_001.out when I stopped myself the calculation with the stop buttom in interactive mode. Can I obtain this message for different reasons?:confused: and then all the next dp are not update. I could run all my calculations on my computer but it takes more time than on the cluster. Is someone meet the same problem? thanks for your help, Véronique |
