Phase Change Modeling (PCM)
Old   July 12, 2016, 02:35
Default Phase Change Modeling (PCM)
Akr
NightWing is on a distinguished road
Hi all,
If i want to model a phase change material (eg. paraffin wax), can i use Eulerian model for it? ( while looking at the user guide, it was mentioned that, eulerian model has a limitation as melting/ solidification cannot be modeled).
So will i be able to perform the analysis using paraffin wax? bcoz initially the paraffin is in solid state and eventually it melts to liquid form by application of heat!
Any inputs?
NightWing is offline   Reply With Quote
Change phase phenomena Imane FLUENT 0 May 4, 2016 15:56
Effective heat capacity - Phase change does not work!!! papteo CFX 8 October 31, 2013 05:15
phase change modeling Danial Q Main CFD Forum 0 April 5, 2012 01:14
phase change with CFX aximefu CFX 5 March 28, 2012 03:38
Solid/liquid phase change using large viscosity gregor.vidmar153 OpenFOAM Running, Solving & CFD 3 June 10, 2010 06:31
