Low Fan Flowrate on Icepak
Old   February 9, 2017, 04:14
Default Low Fan Flowrate on Icepak
Fatih
FatihK is on a distinguished road
Hi, i am modeling a flow where an axial fan(internal) suck the air from open ended channels(fins) at Icepak. Volumetric flowrate data i found from the analysis are less than the experimental ones(which i am sure that experimental data are correct). I tryied zero equation, enhanced two eq. and enhanced RNG. Mesh along the channels and fan are good enough. I meshed using y+ = 5. Even in enhanced two eq. and enhanced RNG flow values are a way less than the actual one. pressure discretization scheme is second order, others are first and i also updated the fan cure wrt. altitude. And energy equation is not solved since, i think it is not necessary. Is there anything that I can do as an improvement
FatihK is offline   Reply With Quote
How to build current blower fan model in Flotherm eric0722 FloEFD, FloWorks & FloTHERM 3 January 2, 2021 02:36
Trouble modelling a jet fan josee OpenFOAM Pre-Processing 0 September 23, 2016 13:06
Obtaining Static Fan Pressure in Icepak robojames ANSYS 1 October 13, 2015 08:02
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 08:24
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
