March 30, 2013, 14:41 |
How To Install Ansys On UBUNTU
Hamed
Rep Power: 13 |
Hello
I am new here. Please Help me to install Ansys 14.5 on ubuntu 12.04 Who could Install and use ansys workbench ubuntu?Please Tell me step by step THX |
April 20, 2013, 10:31 |
Derek Lastiwka
Rep Power: 16 |
I do not believe ANSYS is commercially available for linux anymore.
Derek Lastiwka Mechanical & Fluids Engineer dlastiwka@graymattereng.com Gray Matter Engineering Inc. |
April 20, 2013, 11:52 |
Dmitry
Rep Power: 14 |
it's not that simple as one may think. it's all about workbench implementation on linux.
imho best way to start WB on linux is: 1. To have nvidia card with proprietary driver installed 2. Do install on CentOS or Scientific linux. Since the (almost) official support by ansoft. But you can give a try on ubuntu. And it'd be great if you post your experience after. http://ubuntuforums.org/showthread.p...8#post11931248 |
October 23, 2018, 14:43 |
The required packages from the installation guide (for RedHat/CentOS) are:
• libXp.x86_64 • xorg-x11-fonts-cyrillic.noarch • xterm.x86_64 • openmotif.x86_64 • compat-libstdc++-33.x86_64 • libstdc++.x86_64 • libstdc++.i686 • gcc-c++.x86_64 • compat-libstdc++-33.i686 • libstdc++-devel.x86_64 • libstdc++-devel.i686 • compat-gcc-34.x86_64 • gtk2.i686 • libXxf86vm.i686 • libSM.i686 • libXt.i686 • xorg-x11-fonts-ISO8859-1-75dpi.noarch • glibc-2.12-1.166.el6_7.1 (or greater) 1. Therefore I installed: Code: sudo apt install xterm lsb csh ssh rpm xfonts-base xfonts-100dpi xfonts-100dpi-transcoded xfonts-75dpi xfonts-75dpi-transcoded xfonts-cyrillic libmotif-common mesa-utils libxm4 libxt6 libxext6 libxi6 libx11-6 libsm6 libice6 libxxf86vm1 libpng12-0 libpng16-16 libtiff5 gcc g++ libstdc++6 libstdc++5 libstdc++-5-dev 2. Install manually libXp (not included in the standard repo), you can find it at: HTML Code: https://pkgs.org/download/libxp6 3. Update the database with: Code: sudo updatedb 4. Locate the following libs and create soft links based on your system. I did as follows: Code: sudo ln -sf /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1 /usr/lib/libGL.so sudo ln -sf /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1 /usr/lib/libGL.so.1 sudo ln -sf /usr/lib/x86_64-linux-gnu/libGLU.so.1 /usr/lib/libGLU.so sudo ln -sf /usr/lib/x86_64-linux-gnu/libXm.so.4 /usr/lib/libXm.so sudo ln -sf /usr/lib/x86_64-linux-gnu/libXm.so.4 /usr/lib/libXm.so.3 sudo ln -sf /usr/lib/x86_64-linux-gnu/libXp.so.6 /usr/lib/libXp.so sudo ln -sf /usr/lib/x86_64-linux-gnu/libXt.so.6 /usr/lib/libXt.so sudo ln -sf /usr/lib/x86_64-linux-gnu/libXext.so.6 /usr/lib/libXext.so sudo ln -sf /usr/lib/x86_64-linux-gnu/libXi.so.6 /usr/lib/libXi.so sudo ln -sf /usr/lib/x86_64-linux-gnu/libX11.so.6 /usr/lib/libX11.so sudo ln -sf /usr/lib/x86_64-linux-gnu/libSM.so.6 /usr/lib/libSM.so sudo ln -sf /usr/lib/x86_64-linux-gnu/libICE.so.6 /usr/lib/libICE.so sudo ln -sf /lib/x86_64-linux-gnu/libgcc_s.so.1 /lib/libgcc.so sudo ln -sf /lib/x86_64-linux-gnu/libc.so.6 /lib/libc.so sudo ln -sf /lib/x86_64-linux-gnu/libc.so.6 /lib64/libc.so.6 5. Change the command interpreter for shell scripts: Code: sudo dpkg-reconfigure dash Then answer "No" to the question. 6. From DVD1 install Ansys, launch: Code: sudo ./INSTALL 7. Modify the Linux environment variable ANSYS quick start of each component Modify the hidden files.Bashrc your Ubuntu home directory. Add the following code in.Bashrc. Method for typing in the terminal code: gedit ~/.bashrc paste the following code: # add environment variables: #ANSYS # Workbench export ANSYS180_DIR=/ansys_inc/v180/ansys alias wb2='/ansys_inc/v180/Framework/bin/Linux64/runwb2 -oglmesa' export LD_LIBRARY_PATH=/usr/ansys_inc/v180/Framework/bin/Linux64/Mesa:$LD_LIBRARY_PATH #export XLIB_SKIP_ARGB_VISUALS=1 #uncomment if you have trasparency issues in CFX pre/post or turbogrid export LANG=en_US.UTF8 #CFX export PATH=/ansys_inc/v180/CFX/bin:$PATH #Turbogrid export PATH=/ansys_inc/v180/TurboGrid/bin:$PATH #FLUENT export PATH=/ansys_inc/v180/fluent/bin:$PATH export FLUENT_ARCH='lnamd64' 8. Type the following code: source .bashrc 9. To start ansys use any of the following commands: Ansys CFX Launcher CFX5 CFX-pre cfx5pre CFX-Solver Manager cfx5-solve CFD-post cfdpost Turborid cfxtg Fluent fluent ICEM CFD icemcfd Ansys APDL ansys150 # is really in command mode Ansys150 -g # graphics mode Ansys Workbench runwb2 Use the get command to help command -help Note: The Linux version of Ansys is installed in the Ubuntu is installed by default in /usr/ansys_inc. If you change the default installation location, please modify the path specified in the ansyslmd.ini. Use VIM to open ansyslmd.ini, as follows ANSYSLI_NOFLEX=1 LICKEYFIL=/usr/ansys_inc/shared_files/licensing/license.dat If the fonts are not displayed correctly in gui, run the following: sudo apt-get install xfonts-75dpi xfonts-100dpi xterm ttf-mscorefonts-installer You do need to restart your system (it might be enough to restart the X server)! |
October 23, 2018, 14:52 |
Install ANSYS 18 on ubuntu (x64)
This is the step by step procedure that i followed to get ansys running on my machine. This procedure won't give any library issue.
The required packages from the installation guide (for RedHat/CentOS) are: • libXp.x86_64 • xorg-x11-fonts-cyrillic.noarch • xterm.x86_64 • openmotif.x86_64 • compat-libstdc++-33.x86_64 • libstdc++.x86_64 • libstdc++.i686 • gcc-c++.x86_64 • compat-libstdc++-33.i686 • libstdc++-devel.x86_64 • libstdc++-devel.i686 • compat-gcc-34.x86_64 • gtk2.i686 • libXxf86vm.i686 • libSM.i686 • libXt.i686 • xorg-x11-fonts-ISO8859-1-75dpi.noarch • glibc-2.12-1.166.el6_7.1 (or greater) 1. Therefore I installed: Code: sudo apt install xterm lsb csh ssh rpm xfonts-base xfonts-100dpi xfonts-100dpi-transcoded xfonts-75dpi xfonts-75dpi-transcoded xfonts-cyrillic libmotif-common mesa-utils libxm4 libxt6 libxext6 libxi6 libx11-6 libsm6 libice6 libxxf86vm1 libpng12-0 libpng16-16 libtiff5 gcc g++ libstdc++6 libstdc++5 libstdc++-5-dev 2. Install manually libXp (not included in the standard repo), you can find it at: HTML Code: https://pkgs.org/download/libxp6 3. Update the database with: Code: sudo updatedb 4. Locate the following libs and create soft links based on your system. I did as follows: Code: sudo ln -sf /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1 /usr/lib/libGL.so sudo ln -sf /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1 /usr/lib/libGL.so.1 sudo ln -sf /usr/lib/x86_64-linux-gnu/libGLU.so.1 /usr/lib/libGLU.so sudo ln -sf /usr/lib/x86_64-linux-gnu/libXm.so.4 /usr/lib/libXm.so sudo ln -sf /usr/lib/x86_64-linux-gnu/libXm.so.4 /usr/lib/libXm.so.3 sudo ln -sf /usr/lib/x86_64-linux-gnu/libXp.so.6 /usr/lib/libXp.so sudo ln -sf /usr/lib/x86_64-linux-gnu/libXt.so.6 /usr/lib/libXt.so sudo ln -sf /usr/lib/x86_64-linux-gnu/libXext.so.6 /usr/lib/libXext.so sudo ln -sf /usr/lib/x86_64-linux-gnu/libXi.so.6 /usr/lib/libXi.so sudo ln -sf /usr/lib/x86_64-linux-gnu/libX11.so.6 /usr/lib/libX11.so sudo ln -sf /usr/lib/x86_64-linux-gnu/libSM.so.6 /usr/lib/libSM.so sudo ln -sf /usr/lib/x86_64-linux-gnu/libICE.so.6 /usr/lib/libICE.so sudo ln -sf /lib/x86_64-linux-gnu/libgcc_s.so.1 /lib/libgcc.so sudo ln -sf /lib/x86_64-linux-gnu/libc.so.6 /lib/libc.so sudo ln -sf /lib/x86_64-linux-gnu/libc.so.6 /lib64/libc.so.6 5. Change the command interpreter for shell scripts: Code: sudo dpkg-reconfigure dash Then answer "No" to the question. 6. From DVD1 install Ansys, launch: Code: sudo ./INSTALL 7. Modify the Linux environment variable ANSYS quick start of each component Modify the hidden files.Bashrc your Ubuntu home directory. Add the following code in.Bashrc. Method for typing in the terminal code: gedit ~/.bashrc paste the following code: # add environment variables: #ANSYS # Workbench export ANSYS180_DIR=/ansys_inc/v180/ansys alias wb2='/ansys_inc/v180/Framework/bin/Linux64/runwb2 -oglmesa' export LD_LIBRARY_PATH=/usr/ansys_inc/v180/Framework/bin/Linux64/Mesa:$LD_LIBRARY_PATH #export XLIB_SKIP_ARGB_VISUALS=1 #uncomment if you have trasparency issues in CFX pre/post or turbogrid export LANG=en_US.UTF8 #CFX export PATH=/ansys_inc/v180/CFX/bin:$PATH #Turbogrid export PATH=/ansys_inc/v180/TurboGrid/bin:$PATH #FLUENT export PATH=/ansys_inc/v180/fluent/bin:$PATH export FLUENT_ARCH='lnamd64' 8. Type the following code: source .bashrc 9. To start ansys use any of the following commands: Ansys CFX Launcher CFX5 CFX-pre cfx5pre CFX-Solver Manager cfx5-solve CFD-post cfdpost Turborid cfxtg Fluent fluent ICEM CFD icemcfd Ansys APDL ansys150 # is really in command mode Ansys150 -g # graphics mode Ansys Workbench runwb2 Use the get command to help command -help Note: The Linux version of Ansys is installed in the Ubuntu is installed by default in /usr/ansys_inc. If you change the default installation location, please modify the path specified in the ansyslmd.ini. Use VIM to open ansyslmd.ini, as follows ANSYSLI_NOFLEX=1 LICKEYFIL=/usr/ansys_inc/shared_files/licensing/license.dat If the fonts are not displayed correctly in gui, run the following: sudo apt-get install xfonts-75dpi xfonts-100dpi xterm ttf-mscorefonts-installer You do need to restart your system (it might be enough to restart the X server)! |
July 6, 2021, 03:20 |
A. Min
Rep Power: 12 |
Hi all
is it possible to install Ansys R1-2021 on ubuntu 20.04? |
Install ANSYS 14.5 on Ubuntu | siqma | ANSYS | 1 | December 6, 2013 01:55 |
Ansys 13 - License problem on Ubuntu | MarTar | ANSYS | 4 | February 3, 2012 02:13 |
install Ansys 13.0 on Fedora 15 | 8703303 | ANSYS | 0 | November 7, 2011 10:36 |
Setting ANSYS Install Folder Using The Command Line | rjamison | CFX | 0 | March 22, 2010 22:33 |
How to Install OpenFOAM on 64 Ubuntu 9.04 | hansel | OpenFOAM Installation | 62 | March 19, 2010 14:43 |
