Changes to named selections not appearing in CFX? |
May 13, 2012, 20:28 |
Scott
Rep Power: 14 |
Can anyone suggest why CFX Pre does not always pick up changes in Named Selections that I make in the ANSYS Mechanical Meshing?
Often I'll add or subtract geometry from a named selection or create a new one, hit update, and refresh CFX Pre, but can't see the new named selection in CFX Pre? Any thoughts as to why this is happening? |
June 27, 2012, 20:35 |
Darren Zhang
Rep Power: 14 |
I have the same problem,
do you get the answer? thank you |
July 18, 2012, 02:00 |
Darren Leong
Rep Power: 15 |
Tools>Options>Geometry Import>
Check that Named Selections is enabled (tick left box) and delete the filtering prefixes which usually 'NS' by default. The setting above applies to new projects created after the change tho. |
January 29, 2017, 12:29 |
Luke Whelan
Rep Power: 9 |
Had the exact same problem, added a named selection in the mesh but could never get it to update in the setup. For me, it was solved by doing the following:
File -> Recorded Mesh Options -> Match Zone Names Had to close the solver and open it again to get the new named selection to show up but it seemed to work after that. Don't know why this is the solution, not very intuitive (to me at least). |
cfx, meshing, named selections |
Display Modes | |
Error in recompiling the solver | m.maneshi | OpenFOAM Running, Solving & CFD | 0 | August 28, 2010 14:14 |
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 13:22 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 05:59 |
CFX 10 VS CFX 11 for combustion | Jonathan Lemay | CFX | 2 | May 9, 2007 11:58 |
FSI using CFX and ANSYS | Bi Chang | CFX | 2 | May 10, 2005 04:47 |
