AnilVaswani
Rep Power: 10 ![]() |
is it possible to make new material in ansys from two diff property material.
means we have X and Y known, X + Y = Z we need to analysis and check property of new made material is it possible in ansys or what? |
Prada_007
Rep Power: 0 ![]() |
you can't simply add the engineering data of two different materials in ansys workbench and get a new material (although you can by adding each material property but it doesn't makes any sence at all).
engineering data can't be use as a color mixture where you mix red with yellow and get orange. Instead, eastablish a sole material which best suits your design requirement and find out their material properties of that and input these values in ansys engineering data. thanks, |
AnilVaswani
thanks i just want to know, if ansys can do it or not
Lucky
Rep Power: 68 ![]() ![]() ![]() |
Isn't it obvious that the answer is yes?
Instead of giving Ansys the properties for X you simply give the properties for Z which you have prepared beforehand. You can always define a new material, Ansys doesn't care if you name it Z or (X+Y) |
Display Modes | |
Adding material to CFX material library | marlon | CFX | 2 | October 16, 2016 09:33 |
Material change during phase transformation (FePO4 > LiFePO4) concentration distribut | kimsw0103 | CFX | 0 | January 15, 2016 22:05 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
