FSI 2-way with Fluent (Error High distortion)
Like Tree2Likes
  • 2 Post By RaiderDoctor
Old   April 24, 2017, 06:09
Default FSI 2-way with Fluent (Error High distortion)
Youssef Fathallah
YoussefFath is on a distinguished road
Hi!
I´m new in this forum and I search information about a FSI 2-way error.
I am trying to simulate a artery (cylinder) with the blood, with a variable pressure-input and a pressure-output in fluent. When I run the system coupling I had a error which said there was a elements with high distortion.
I tried very solutions but I don´t have any improvement.
I attached two images with the error
P.D: Sorry for my english and thank you.
Tags: FSI, system coupling, High distortion, biosimulation, transient structural
YoussefFath is offline   Reply With Quote
Old   May 21, 2017, 13:06
RaiderDoctor is on a distinguished road
Element distortion in the Mechanical solver is usually due to the load (in this case, from the fluid) being applied too quickly. The usual way to deal with this is to simply restart your analysis from a time step that was close to where it failed. This time, however, you want to decrease your step size so that the load is applied much more slowly.
Say, for instance, your original time step size was 0.002 s, and the simulation failed at 0.43 s. You would want to restart your simulation at a point close to 0.43 s, but this time with a step size of 0.001 s. That's the easy part.
Now, for the hard part: how do we do this? Unfortunately, this has to be done prior to running your simulation. Ansys is fickle, and will not hesitate to delete your solution files if you touch the wrong thing. Even if you change it back, the solution files are gone. A good practice, if you have the memory, is to save your simulation immediately after it fails so that you always have a back-up plan.
Setting up restart points is fairly simple, so that's the nice part. Check out this youtube video (Restarting a Coupled Analysis in ANSYS Fluent and Mechanical, https://www.youtube.com/watch?v=ef9XGXyuJHY) which should go over the basic steps. Check the documentation and write down what you do so that you can check back on it later.
If, in the instance, you already know how to do all of this, another issue might be your element quality. Check the quality and aspect ratio within mechanical and verify that it is still good. If it isn't, consider remeshing. Be warned, however, that this will delete your solution files and you will need to restart from scratch.
Good luck!
sadjad.s and micheldang like this.
RaiderDoctor is offline   Reply With Quote
problem with creating artery thickness for FSI methode using fluent and mechanical raminostadi FLUENT 1 June 6, 2020 05:17
ANSYS, FLUENT, 2-way FSI with solid motion and deformation in a cubic canal Hosein.Amiri ANSYS 3 June 28, 2017 20:47
Icepak Results Used by Fluent for FSI Alan Shao FLUENT 0 April 8, 2016 08:59
One-way FSI... can I start with structure and then transfer solution to Fluent YANNAPOL FLUENT 1 April 1, 2015 15:52
FSI Fluent -> static structural zytra ANSYS 4 October 16, 2014 17:01
