A negative temperature value (-700°C) appears during the welding simulation |
Zhuozhao Wu
Rep Power: 0 ![]() |
Hallo,everyone
I am doing a simulation on Multi-layer welding with ANSYS by using the double ellipsoid heat source and Element Birth Technique. In the simulation process there has been a very strange phenomenon. If I use the BFE command to apply the heat generation rate to the element, some elements, which are not activated, have results -700°C temperature, but the final result is correct. However, if I use the BF command to apply the heat generation rate to the node, the phenomenon of -700°C does not exist, but the final result is wrong. What is the reason? How should I solve it? Thanks a lot |
#2 | |
Liaoning
Rep Power: 13 ![]() |
Hi, I just share my result on youtube ,check it out here https://www.youtube.com/watch I think you should take care of boundry condition |
Display Modes | |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
higher temperature in the simulation | kcgmech | Fluent UDF and Scheme Programming | 1 | March 10, 2016 06:11 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
help,why the negative energy source does'nt make the temperature decrease, thank you! | hunter | FLUENT | 6 | May 12, 2010 17:39 |
