May 25, 2017, 08:06 |
[ICEM] pipe L=50 m d=0.008 m mesh
Karandashev Artem Dmitrievich
Hello everybody!
I build a grid for a long thin pipe. I used this similar material: https://www.youtube.com/watch?v=hZ6gIzG7RXk . Construct approximatively by this method was obtained for pipes with a length of 1, 10, 25 meters. But in the construction of a 50 m pipe by this method, the preliminary grid is built only on the end surfaces. How to build a grid for this pipe 50 meters? 3d-mesh Attaching 1) the geometry of Parasolid 2) photos of grids 1, 10, 25 meters (it turned out) 3) photo grid 50 meters (problem) |
May 25, 2017, 09:28 |
D. N. Venturi
Rep Power: 13 |
try re-associating the block faces to your outer and inner walls (Associate face to surface). And make sure you have set a number of divisions in that edge. |
May 25, 2017, 10:51 |
Hi, Venturi
Associate face to surface - Without results number of divisions in that edge - Without results Pre-mesh does not change after the adjustment. Do we have any idea? |
May 25, 2017, 12:40 |
D. N. Venturi
Rep Power: 13 |
If you could attach the files, I can take a look.
icem long pipe |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[ICEM] [icem] split geometry to mesh | blgypeng | ANSYS Meshing & Geometry | 5 | October 5, 2013 10:11 |
[GAMBIT] 3D Two pipe T-shape junction mesh | Jing | ANSYS Meshing & Geometry | 8 | April 26, 2013 12:27 |
[ICEM] Octree surface mesh issue | siw | ANSYS Meshing & Geometry | 6 | February 13, 2011 12:46 |
[blockMesh] generate a graded pipe mesh. | jenright | OpenFOAM Meshing & Mesh Conversion | 0 | August 22, 2009 08:58 |
