yardena jodeck
Rep Power: 10 ![]() |
Why when I calculate mass fluxes imbalance it says 1exp-5 and if I proceed with more iterations it change to 1exp-3?
Ty |
Rep Power: 14 ![]() |
Do you have re-circulations from outlet?
yardena jodeck
I have a zone call momentum source that produce a recirculation zone (fuente mom). In my model I have two recirculation zones but in different places. So it takes air from the botton and reinject the same amount of air at top ...like a centrifugal fan. In one of the photos that I have posted here, the second source gives a postive value and the flux imbalance is 1exp-6. Then the flux imbalance past from positive to negative to a value like -0.001. I dont understand. Do you have an idea of how can I explain this? Anything |
I don't quit understand what i'm looking at in the pictures. Are these mass fluxes?
How can you have mass flux from an interior? I dont understand your setup.. ![]() |
yardena jodeck
That values are in kg/s.
There is mass fluxes but the source is in N/m3 so is doesnt counts as inlet or outlet it is just for moving air though it. The mass imbalance is computed with Inlets: "velocity_inlet_q1", "velocity_inlet_q2" And Outlets: "pressure_outlet" Sent from my SM-G570M using CFD Online Forum mobile app |
Unfortunatly i'm not an expert with compressible medium you are using.
Your mass balance seems quite good still. So i would monitor this value with further iterations. In general mass imbalance should get smaller with better convergence, so in reverse one could assume, that you're currently not converging correctly. But i would monitor more values to judge convergence here, one of the values being mass imbalance. Are your momentum sources time dependet or constant? Your are simulating steady state, right? |
Display Modes | |
OpenFOAM - Validation of Results | Ahmed | OpenFOAM Running, Solving & CFD | 10 | May 13, 2018 18:28 |
Oscillating Airfoil Poor Results at High k (reduced frequency) | dancfd | OpenFOAM Running, Solving & CFD | 3 | November 4, 2013 08:32 |
Creating a tool to interpolate results | Luis Batista | OpenFOAM Running, Solving & CFD | 2 | April 11, 2013 08:15 |
Transient Run - Output "Time" in partial results? | evcelica | CFX | 2 | May 16, 2012 21:36 |
wind tunnel results vs fluent | pixie | Main CFD Forum | 1 | August 20, 2009 08:02 |
