August 11, 2017, 09:34 |
air conductance in thermal model
Hi
First question on this forum. Hope to learn and help others a lot :-) I am using ansys thermal steady state. The model is basically a metal block with some complex geometry with a local heatsource and heated to approx 600 C. The block is placed in a very large vacuum chamber(10mBar). The heat loss to the vacuum chamber would consist of radiation and conduction. I am trying to add air conductance to the model, but I can only find convection and radiation. The question is : how do I add air conduction to the model? Ultimately I want to add conductance as a function of pressure "https://www.electronics-cooling.com/2002/11/the-thermal-conductivity-of-air-at-reduced-pressures-and-length-scales/" Thanks for the help. :-) |
air, ansys, conductance, pressure, thermal |
Display Modes | |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Compact Thermal Model | m_f | OpenFOAM Programming & Development | 0 | July 19, 2012 04:35 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 01:40 |
