CFD Engineer
Rep Power: 9 ![]() |
Hello
could any one help me how to setup steam explosions in ansys ? using which models can this is possible my problem is Simulating a hot pipe a hot steel pipe is heated to 900 degree centigrade and water is sent into pipe through 5 mm dia inlet dimensions of pipe are dia 60mm lenth 600 mm it has no outlet. inlet water temperature is 25 degree centigrade with 1 bar i want to solve transiently i want to find the pressure inside the pipe due to the phase change from water to steam required pressure is 600 bar inside the pipe . i want to find in how much time does the required pressure is achieved can you suggest me which models i have to use and how to solve this problem thanks in advance Karthikeya |
Display Modes | |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Setting boundary conditions for simple pipe flow with flow direction changing in time | Sipher | FLUENT | 1 | May 4, 2015 21:05 |
High values of heat transfer coefficient for laminar flow in pipe | Allankey | CFX | 2 | May 28, 2014 13:44 |
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) | florian_krause | OpenFOAM | 22 | June 13, 2013 22:25 |
Turbulence in a pipe flow | JM | Main CFD Forum | 4 | December 21, 2006 05:04 |
