Home > Forums > Software User Forums > ANSYS
Heated Panel onto Heat Pipes cooled by water pipe
Old   November 20, 2017, 14:26
Question Heated Panel onto Heat Pipes cooled by water pipe
Chris in the mix is on a distinguished road
I need to model the following experiment:
* A Heated Panel, which includes several different material layers,
* 9 parallel Heat Pipes at its backside
* with a Water Pipe passing through all of the condensers in series
* water is provided by a closed system, including a water tank.
The experiment ends once the water tank has reached 45Celcious(3-4hours in 30s timesteps)
What strategy shall I use to model this experiment ? Bare in mind that the HEAT PIPES are the focus of the study.
Shall I use:
* ICEPAK for the plate then import the data onto
* FLUENT for the heat pipes + water pipe ?
That wouldn't work because the two systems affect each other. Is ICEPAK even necessary ?
Chris in the mix is offline   Reply With Quote
fluent, heat pipe, plate heat exchanger
No liquid water exist in my Fuel Cell simulation fatchang FLUENT 19 October 15, 2018 14:27
Vertical Pipe water flow Goutam FLUENT 0 April 30, 2014 08:25
help needed : 2d water flow in heated pipe abuabdellah.albatal FLUENT 6 May 4, 2012 03:10
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
