Clipped Isosurfaces - show volume as percent?
1 Attachment(s)
When showing capped isosurfaces, is it possible to show the volume as a percent of the part that is below the capped stress?
I attached a picture as an example, I thought I've seen percentage shown in the upper left region. |
Hi Joe,
The only way I found is to export the capped iso-surfaces as an .stl and query the volume in SC -> rmb on result > export > stl. Have fun ;) |
What is SC?
SpaceClaim. You can also use MeshMixer or Meshlab both are freeware.
