FLUENT Bad results
Old   November 24, 2017, 10:06
Default FLUENT Bad results
Giacomo Dall'Olio
giacodall94 is on a distinguished road
Hi Guys,
I'm having a trouble finding drag forces over a motorbike.
I get a drag force of about 40 N which give me a Cd of about 0.07
This result is obviously wrong , the magnitude of Cd is usually around 0.5 in this case...
The case seems well scaled,
Mesh is ok ( not wrong enough to give such a bad result, i hope )
k-epsilon realizable
Residual of k,epsilon, continuity around 1e-02
Residuals of speeds aroun 1e-05
Energy below 1e-07
cd and cl almost constant after 1000 iter.
Where can i start to find the cause of my problems ?
I ' ll appreciate every tipe of aid.
Thanks a Lot
G
giacodall94 is offline   Reply With Quote
SU2 Transonic Flow simulations bad results S.Kontogiannis Main CFD Forum 8 May 16, 2014 12:22
Results from REAL experiment and FLUENT are not equal ? notecool24 FLUENT 3 January 19, 2014 17:41
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 02:00
how to set the fluent to show the 3D results in the xz plane? poiu FLUENT 8 January 30, 2013 06:51
Surce Terms fluent bad results Mihai FLUENT 2 May 11, 2005 07:36
