November 24, 2017, 10:06 |
FLUENT Bad results
Giacomo Dall'Olio
Hi Guys,
I'm having a trouble finding drag forces over a motorbike. I get a drag force of about 40 N which give me a Cd of about 0.07 This result is obviously wrong , the magnitude of Cd is usually around 0.5 in this case... The case seems well scaled, Mesh is ok ( not wrong enough to give such a bad result, i hope ) k-epsilon realizable Residual of k,epsilon, continuity around 1e-02 Residuals of speeds aroun 1e-05 Energy below 1e-07 cd and cl almost constant after 1000 iter. Where can i start to find the cause of my problems ? I ' ll appreciate every tipe of aid. Thanks a Lot G |
SU2 Transonic Flow simulations bad results | S.Kontogiannis | Main CFD Forum | 8 | May 16, 2014 12:22 |
Results from REAL experiment and FLUENT are not equal ? | notecool24 | FLUENT | 3 | January 19, 2014 17:41 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
how to set the fluent to show the 3D results in the xz plane? | poiu | FLUENT | 8 | January 30, 2013 06:51 |
Surce Terms fluent bad results | Mihai | FLUENT | 2 | May 11, 2005 07:36 |
