November 29, 2017, 13:34 |
Cavitation
Joseph M
Rep Power: 8 |
I have just completed my impeller design using Vista CPD and created the cavitation simulation on Ansys CFX. However, I am having some difficulty with two important things. What is the method required to show the effect of cavitation on vibration using Ansys? I would like to show the vibration effects caused by the vapour bubbles on the impeller. Furthermore, is there a way to show the Vibration Spectrum of the impeller which shows the peaks caused by the cavitation. I heard that this involves determining the flow induced vibrations on Ansys.
The attached pictures shows both the steps which I have undertaken and the cavitation effects on a small section of the impeller. The red section on the impeller shows the areas where the cavitation effect are very prominent. |
why doesn't ansys allow a negative pressure when cavitation is included | vysje | CFX | 16 | December 11, 2016 17:18 |
fetal overflow in user defined cavitation model | unclewallcn | CFX | 15 | January 20, 2016 22:17 |
Cavitation in Pure Ethanol | Pugnax | CFX | 4 | June 18, 2015 20:19 |
Centrifugal Pump Cavitation problem or not. | ismael.s | CFX | 13 | February 27, 2012 08:00 |
Combining Cavitation and Thermal Effects? | akash_max | CFX | 4 | January 19, 2012 14:09 |
