Problems with pretension bolts
Old   February 1, 2018, 02:45
Default Problems with pretension bolts
javier
javierao is on a distinguished road
Hi everyone!
right now im making a model (static structural) using steel material,my model has a lot of bolts and i need to use the tool of pretension. The geometry that im using was drawn in autoCAD. the problem is that its too dificult to reach the convergence on the first step of pretension.
can you give me some tips or advices to solve my problem?.
im using frictionless contacts between the bolt, nut and the connecting parts,
javierao is offline   Reply With Quote
Old   February 2, 2018, 22:59
Christophe is on a distinguished road
Use frictional. Make sure the diameters between threaded components are identical. Make sure there is a clearance between the bolt and the component it is not threaded into so that ANSYS doesn't automatically generate a contact interface there. Only apply preload in first time step. Make sure your model is adequately constrained.
Christophe is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[mesh manipulation] Problems with rotational cyclic boundaries TReviol OpenFOAM Meshing & Mesh Conversion 8 July 11, 2014 04:45
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 07:44
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 06:44
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 12:00
