Setting Aspect Ratio
Old   February 6, 2018, 06:36
Default Setting Aspect Ratio
Keerthy
Kirti is on a distinguished road
Currently I am trying to work on static structural Analysis with a Mesh imported from ICEM CFD.
I receive the following Error message,
Element 22705 located in Body "Solid Body 10(ICEM CFD)" (and maybe other elements) has become highly distorted.
Excessive distortion of elements is usually a symptom indicating the need for corrective action elsewhere.
Try incrementing the load more slowly (increase the number of substeps or decrease the time step size).
You may need to improve your mesh to obtain elements with better aspect ratios.
If this message appears in the first iteration of first substep, be sure to perform element shape checking.
I wish to change the Aspect Ratio to 1000, How can I do it.
Thanks
Kirti
Kirti is offline   Reply With Quote
[ANSYS Meshing] Aspect ratio of 3D simulation of flow over turbine with k-omega, SST TKP ANSYS Meshing & Geometry 0 October 8, 2015 12:26
[Other] Aspect Ratio CFX Solver tomson199 ANSYS Meshing & Geometry 4 August 27, 2015 11:12
[Other] How is aspect ratio computed? musahossein OpenFOAM Meshing & Mesh Conversion 10 February 22, 2015 13:13
[ICEM] Mesh along axis for a wedge gives elements with extreme aspect ratio sangrampp ANSYS Meshing & Geometry 0 November 17, 2010 07:57
SOS, postprocess aspect ratio hedonist FLUENT 3 September 1, 2010 11:02
