8 simulations: 1 after the other in parallel or 8 in serial? |
Rep Power: 10 ![]() |
Hello everbody,
mc cpu has 8 cores. i have now 8 simulations to do, which will take a lot of time. What do you think is faster: - to run all 8 simulations simultaneously in serial mode - to do one simulation after the other in parallel mode with 8 cores per simulation? Best regards h0rst |
Hello h0rst,
Do one simulation in parallel mode with 8 cores. Simultaneously, you can check the residuals for solution convergence. So once after converging the solution with conclusive results, you can proceed with other cases promptly. Thank you |
#3 | |
For large cases I will check RAM etc. So may be 2 or 1 at most. |
Gert-Jan
Rep Power: 28 ![]() |
If you run them serial, you need 8 solver licenses. Do you have them?
Display Modes | |
multiphaseEulerFoam running in serial but crashing in parallel | BlnPhoenix | OpenFOAM Running, Solving & CFD | 1 | May 4, 2017 03:40 |
Serial UDF is working for parallel computation also | Tanjina | Fluent UDF and Scheme Programming | 0 | December 26, 2013 18:24 |
Serial vs Parallel | eliwardian | Main CFD Forum | 7 | September 6, 2011 15:03 |
serial run fine, but parallel run diverged | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | October 6, 2009 08:33 |
Help: Serial code to parallel but even slower | Zonexo | Main CFD Forum | 4 | May 14, 2008 10:26 |
