Thermal expansion under elevated temperatures |
March 25, 2018, 15:04 |
Rep Power: 9 |
I am trying to model a fire protection collar which changes its volume under elevated temperatures. Basically, I have a wall consisting out of few layers and I have a pipe in it (). On both sides of the pipe I have a fire collar, which expands in fire in one direction, crushes the pipe, and closes the hole (Picture 1). For the beginning, I would assume that the expansion is linear over the time. Is it possible to simulate the expansion in Transient Thermal analysis and develop the temperature profiles? Or do I have do model the expansion in Transient Mechanical analysis and couple these two? In that case I can't first develop the temperature profiles, because the volume will change according to the temperature. Any ideas? |
[blockMesh] Create internal faces as patch in blockMesh | m.delta68 | OpenFOAM Meshing & Mesh Conversion | 14 | July 12, 2018 14:43 |
Question about thermal expansion coefficient | side_attack | Main CFD Forum | 0 | December 20, 2013 08:15 |
Calculte change in length due to thermal expansion. | Sargam05 | OpenFOAM | 0 | March 29, 2013 23:23 |
thermal expansion coefficient setting up | Jiuan | FLUENT | 1 | March 2, 2009 04:55 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
