how to mesh complex 3D geometry
Old   April 18, 2018, 13:34
Default how to mesh complex 3D geometry
Suvansh Mani
SUVANSHMANI is on a distinguished road
how to mesh the 3D geometry which is imported from Solidworks it is not a watertight geometry. I am a beginner so Please suggest me about that
SUVANSHMANI is offline   Reply With Quote
Old   May 3, 2018, 12:10
Default Water tight geometry
Maria Carvalho
mdoracarv is on a distinguished road
I had a loto of problems learning that too. First watch some Youtube videos, they are very helpful. Then start using the tools for fixing geometry, but some times they create bugs and in that case it is best to erase tha bad part and reconstruct it. It's a case bay case analysis. But again, watche the videos.
mdoracarv is offline   Reply With Quote
Old   May 6, 2018, 14:18
Matthew Shorter
matthewshorter is on a distinguished road
It is generally better to fix as much geometry as possible in the native CAD system using either parametric or synchronous (dumb body) modeling tools. Depending on your workflow you might need to tell the CAD practitioner to do this for you. Both ANSYS and Solidworks have tools to check model geometry for self intersection, small features, etc. that you can use to prepare the model.
matthewshorter is offline   Reply With Quote
Old   May 8, 2018, 13:25
plucas's Avatar
Anonymous
plucas is on a distinguished road
Fix what you can in Solidworks and then finalize the fixing in Spaceclaim.
plucas is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[ANSYS Meshing] How to mesh this geometry to get best quality?(provide your suggestion) Roh ANSYS Meshing & Geometry 1 October 10, 2017 14:23
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh czhongrong OpenFOAM Meshing & Mesh Conversion 1 January 20, 2016 06:26
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Gambit - Mesh Problem for a complex 3D geometry Nelson FLUENT 3 May 28, 2012 07:57
