November 30, 2019, 23:49 |
Spray combustion modeling in ansys fluent
Anusai Ramankutty
Rep Power: 6 |
I am using DPM for modeling spray combustion.
The combustion is non premixed, modeled using a pdf generated. The atomizer model used is pressure swirl atomizer model in fluent. The turbulence model used is realizable k-e with enhanced wall treatment. I ran cold flow simulations that converged to residuals 10e-5, but hot flow is fluctuating around 10e-2. Please help. |
combustion, dpm convergence, fluent, spray |
Is corrosion modeling possible in Ansys Fluent? | Blue | FLUENT | 0 | October 14, 2018 21:05 |
Fused Deposition Modeling Process Simulation in Ansys Fluent | ttp262 | FLUENT | 0 | October 2, 2018 16:07 |
ICE fluent (ANSYS): calculation is complete with combustion | Mutairi_33 | FLUENT | 1 | July 21, 2018 18:03 |
Modeling of evaporative cooling pad on ANSYS Fluent | Vishnu_1991 | Fluent Multiphase | 0 | June 5, 2014 15:17 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
