Question on Moisture Latent Heat
Old   May 16, 2018, 13:37
Default Question on Moisture Latent Heat
Kaimynas
kaimynas is on a distinguished road
Hey, got a question about Moisture Latent Heat http://prntscr.com/jip6ui
Basically my question is how to find out moisture latent heat if i change proximate/ultimate analysis, for example: http://prntscr.com/jip7mo everything is different but not sure about moisture latent heat. Also follow up question, if i put LHV instead of HHV, the moisture latent tab disappears and i dont need to specify it, so maybe if i define LHV instead of HHV, results arent gonna change that much?
kaimynas is offline   Reply With Quote
question about Heat transfer between two phases with VOF model sooroo3 FLUENT 0 February 15, 2011 04:24
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Latent Heat of Fusion J.W.Ryu FLUENT 0 May 24, 2002 04:27
Latent heat introduced by the TEM1 equation? H.P.LIU Phoenics 1 January 11, 2001 11:03
