Ported Shroud
Hello, i would like to ask a question about turbogrid. I want to create a ported shroud centrifugal impeller. So, my question is if it's possible to split shroud surface in smaller parts in order to connect one with the port via Frozen rotor. Is there any different way? Thank you
Did you ever have any success with this? I'm trying to do the same. I've split the shroud face in Design Modeler, but that split does not carry over into Turbogrid.
Yes, my solution was been to import the mesh as .CGNS from Turbogrid to Icem and here manually add some faces meshes in a new part. |
Good idea. Unfortunately I don't have an ICEM license. I do have meshing in Workbench, but it doesn't seem like you can modify an imported mesh. I'll have to try and figure something else out.
