May 28, 2018, 20:36 |
Print out coordinates of cells in Icem
sofiathomsons123
Hi
I would like to print out the coordinates of the cell centers at the inlet selection on a mesh to a separate data file. Does anyone know a way to do this in icem cfd? The mesh is created in icem, but I got other software such as fluent available if it's necessary to export the mesh into another format. Regards Last edited by sofiathomsons123; June 2, 2018 at 10:29. |
May 31, 2018, 00:36 |
Lucky
Rep Power: 65 |
Do you mean cell centers or face centers? There are no cell centers on boundaries, unless you mean the centers at cells that are adjacent to boundaries. I'm not sure how to do it for boundary adjacent cell centers but for face centers....
In Fluent after importing the mesh and initializing with a dummy solution you can go to export solution data and can export any variables, it will dump the x,y,z coordinates of each mesh node/cell depending on your selection. If you choose the cell zone then it gives all cells. If you chose a surface (including the interior surface) it it gives faces. You could also export a PROFILE of any variable, which will also dump the cell/face centers. |
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times | vidyadhar | ParaView | 9 | May 20, 2020 20:06 |
[snappyHexMesh] sHM too many cells | Knapsack | OpenFOAM Meshing & Mesh Conversion | 2 | July 8, 2017 07:41 |
volScalarField: how to get the coordinates of the cells | mrv4real | OpenFOAM | 5 | January 17, 2012 06:21 |
[ICEM] Exporting Cartesian coordinates from ICEM to Matlab? | user_of_cfx | ANSYS Meshing & Geometry | 0 | October 17, 2011 10:17 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
