Fluent: Proper Solver for Pressure ratio in high pressure turbine |
September 20, 2018, 03:00 |
BB
I have to calculate pressure ratio of high pressure turbine. Turbine is a part of jet engine. I have doubts if it is possible to count that in fluent because I'm not sure if Fluent can solve case when the stream should move rotor blades. I have data like: - pressure before turbine - mass flow rate - blades rotation speed In my case I set: - pressure-based, Steady - K-epsilon, Realizable, Enchanted Wall Function - moving frame with rotation-Axis Direction (1,0,0) and Rotation speed 870 [rad/s] - BCs: pressure-inlet, pressure-outlet, rotation vector of walls (1,0,0), periodicity - Scheme: Coupled, Gradient: G-G Node Based, Pressure: Standard, Momentum & Energy: Second Order Upwind, Turbulence Kinetic Energy & Turbulence Dissipation Rate: Power Law I would like to ask You if that settings are correct. What's more I would like to know if should add rotation speed -870, because I know this is how it should be done with compressors. I am looking forward to hearing from You, Lotd |
fluent, frame, moving, rotation, turbine |
Display Modes | |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 07:00 |
Simulating movement of air from low to high pressure in Fluent | jwillie2000 | FLUENT | 0 | April 11, 2013 05:18 |
Fluent natural ventilation pressure boundary condition | pierresandre | FLUENT | 24 | November 8, 2011 15:32 |
Fluent Vs CFX, density and pressure | Omer | CFX | 9 | June 28, 2007 05:13 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
