ANSYS AIM : Measuring pressure values on individual section |
July 5, 2018, 06:30 |
Vinayak-
Rep Power: 7 |
In the sectional view of my fluid geometry, there are multiple regions separated from each other. I want to calculate average pressure values in each of those regions.
Example : Consider two pipes parallel to each other. The flow volumes through those pipes are also parallel. If we take a section plane across the pipes, two separate regions are formed in that plane. Whenever I try to measure average pressure using pressure contour defined using my section plane, it shows the average pressure value of all the regions, not individual regions. If I do the same thing in Autodesk CFD, I will get the average pressure values at each region of that section. Like pressure at region 1= x bar, pressure at region 2 = y bar Please help me find a way out.
Thanks, Vinayak |
October 4, 2018, 03:14 |
Vestdam
Rep Power: 8 |
When you create the plane, you can select which body to refer to. I think you have to make two planes, one for each domain.
Issues with pressure drops and values | KiruBiru | CFX | 2 | November 24, 2017 05:34 |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
2-way FSI in Ansys CFX 15 | LucasGasparino | CFX | 3 | August 6, 2015 03:17 |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 16:29 |
