How to write the script to measure perimeter in Spaceclaim? |
October 2, 2022, 07:50 |
Wu Yi-Lin
Hi, guys
I'm facing a difficulty: In Spaceclaim, I created 424 faces in Sketch Mode in STL file because I want to measure the cross-sectional area and the perimeter of each face. And I wanted to write a script to make it measure automatically. However, there was an error message which is " 'Body' object has no attribute 'Perimeter' " when I tried to run the code to measure perimeter. Here is my code below: selection=FaceSelection.FilterByVisible(FaceSelect ion.SelectAll()) perimeter =list (face.Shape.Perimeter for face in selection.Items) print(perimeter) Can someone help me? Thank you in advance, Joean. |
October 2, 2022, 17:31 |
#2 | |
Austin
Rep Power: 5 |
October 4, 2022, 03:02 |
#3 | |
Wu Yi-Lin
Thank you for your reply. That's a good idea that selects each edge of each face, and I will try later. I've figured out another way to solve this problem. Here is the modified code: selection = FaceSelection.Create([GetRootPart().Bodies[0].Faces[0], GetRootPart().Bodies[1].Faces[0], GetRootPart().Bodies[2].Faces[0], GetRootPart().Bodies[3].Faces[0], ... GetRootPart().Bodies[423].Faces[0]]) perimeter =list(face.Shape.Perimeter for face in selection.Items) print(perimeter) Joean |
script error, spaceclaim |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
[Helyx OS] Helyx-OS (GUI for SnappyHexMesh | elvis | OpenFOAM Community Contributions | 210 | January 30, 2017 18:57 |
[DesignModeler] How to write the script in the ansys design modeler? | deddy1973 | ANSYS Meshing & Geometry | 3 | October 4, 2013 05:08 |
how I can write the file script to submite via HPC cluster at my UNI | happy | CFX | 2 | October 17, 2011 02:18 |
pmovlink script | Arnab | Siemens | 4 | August 1, 2004 22:50 |
