July 8, 2019, 02:42 |
Define Two Stacked Up Material
Rep Power: 7 |
I am simulating air flow and thermal comfort analysis inside a bus cabin. For now the opaque body surface are defined by a surface of aluminum with 4mm thickness. However I would like to add additional material (insulation) coupled with the existing aluminum body.
What I would like to know how can I create two stacked material properties (aluminum body coupled with insulation material) to be used in FLUENT? What changes are needed for the geometry? Attached below is an image of the cross section of coupled material. Thank you in advance. |
July 19, 2019, 02:43 |
Joe
Too search answer on this question,can it stuck with aluminium>?
HELP----Surface Reaction UDF | Ashi | Fluent UDF and Scheme Programming | 1 | May 19, 2020 21:13 |
[stressAnalysis] how i can define the material type? | e-nikookar | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 3 | January 2, 2015 00:01 |
How to define a material with orthotropic conductivity in CFX? | mega2tera | CFX | 0 | July 11, 2014 05:10 |
how to define material property like density in fluent which is pressure and temperat | Pushpendra Kumar | Main CFD Forum | 0 | January 17, 2013 23:38 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
