July 7, 2019, 13:22 |
Udf fluent: automating air flow in air duct
AH
Rep Power: 12 |
Need some help please, anyone.
Attached file shows a flow chart for a c++, with initial c++ code shown. Writing c++ UDF independent, since I will be compiling outside fluent first. Will adapt to udf fluent format later. A flow sensor measures air speed in duct. Based on preset airflow speed, pressure is adjusted by 10% (increase or decrease) depending on airflow speed. Increments/decrements of 10% per a loop is done per a conditional airflow check, till required airflow is achieved. The attached flowchart should clarify this. Thanks in advance. If you can't see attachment, will upload again. |
Display Modes | |
Modeling Furnace Air Flow | elisioo | FLUENT | 0 | April 4, 2019 10:16 |
Ansys fluent: Turbulent air through duct | GreenJayPackers | CFD Freelancers | 6 | May 11, 2016 04:14 |
Evaporation Modelling of a single droplet resting on a heated duct with air flow | shashankmechguy | Fluent Multiphase | 0 | June 11, 2015 11:46 |
Different flow patterns in CFX and Fluent | avi@lpsc | CFX | 6 | April 17, 2012 02:22 |
UDF, air flow through a cell----get velocity in | lig | FLUENT | 0 | September 6, 2010 14:02 |
