CFD-Post: Averaging results across different cases to generate a new case |
August 16, 2019, 04:09 |
Shannon Kieran
Rep Power: 6 |
I have four different results files based on the same geometry and mesh, but with slightly different inlet conditions. What I would like to do is average velocity across all four cases at every point to generate a fifth case that represents the average of all four, which I can then post-process in the usual way to generate contour and vector plots, etc. Is this possible to do in CFD-Post? Apologies if this is an elementary question, I've tried to find the answer but haven't had any luck. Thank you in advance! |
August 19, 2019, 05:40 |
Carlo_P
Rep Power: 7 |
Hey Shanny,
what you can do is restart a new simulation that interpolate the results from the previous one. When you start CFX solver, you can start from previous runs. It will interpolate between the given solutions. Maybe this can be a solution. Otherwise, you can export the data of each simulation in Ensight format ASCII and interpolate later "manually" with Excel the data. Obviusoly, this works well with a limited number of cells |
How to Connect 2 cases in CFD Post | AK5 | CFX | 5 | May 30, 2017 05:11 |
Plotting transient results in cfd post or fluent | suyesh | Visualization & Post-Processing | 1 | May 13, 2016 09:54 |
CFD Post - How to check for case in an expression | pilakin | ANSYS | 0 | September 26, 2014 04:44 |
FEA results within CFD Post | delaneyluke | ANSYS | 0 | October 24, 2013 09:30 |
