August 28, 2019, 08:29 |
Unable to start geometry editor - Centos7
br_
Hi Everybody,
I researched a lot of forums to solve this problem. But they don't help me. Ansys licences are works very well. Workbench is opened normally. But when i create the fluent environment and i try to open the Geometry editor the following error pop-up: Unable to start the geometry editor. Please help System: centos7 Ansys version: 19.0 |
July 26, 2021, 05:31 |
Piotr Prusinski
Rep Power: 16 |
I know it passed some time since the post showed up, but I found the same problem just now. I have exactly the same setup as you specified (OS and ANSYS WB version). I use a workflow made of 3 blocks, i.e. geometry, mesh and Fluent... What I found is that only geometry and mesh don't run while Fluent starts and proceed smoothly. Another interesting fact is that all these worked well till the Febrary/March this year. Since I haven't use it (geometry or mesh) for some time so I haven't realized the problem exists. If someone knows some solution or find similar problem would be nice to know.
Regards, Piotr |
[CAD formats] Unable to import STL properly to create final geometry | miguel.delasheras | OpenFOAM Meshing & Mesh Conversion | 2 | January 27, 2019 06:27 |
[DesignModeler] Unable to Import Geometry | Alan212 | ANSYS Meshing & Geometry | 3 | March 17, 2015 11:26 |
[ANSYS Meshing] How to start meshing this geometry? | Thomashoffmann | ANSYS Meshing & Geometry | 4 | March 15, 2013 23:23 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
Unable to start fluent in parallel mode | Anand | FLUENT | 1 | January 11, 2009 16:48 |
