Semisubmersible Ansys Aqwa Meshing Error
Old   December 17, 2019, 07:03
Default Semisubmersible Ansys Aqwa Meshing Error
denwlein is on a distinguished road
I have tried to mesh a semisubmersible geometry in Ansys aqwa through hydrodynamic diffraction. As i run the solution i get the error:
1)elements must be at least 1.000x Facet radius apart.
2)The ratio of the areas of adjacent elements must be less than 0.333
to avoid this i enable the GOON option KrogerFeedback which means it avoids the errors but it gives me the following error for a number of elements.
UNDERWATER SIDE # 1 ON ELEMENT#21133 IS NOT CONNECTED TO ANOTHER ELEMENT. THIS MAY CAUSE PRESSURE ERRORS AND WILL CAUSE HULL PRESSURE CONTOUR ERRORSI have checked the mesh it does look good. has triangular elements and is within the element limit. they are all connected to node points.
Is there any other way to bypass this issue of meshing.
denwlein is offline   Reply With Quote
Pressure outlet boundary condition rolando OpenFOAM Running, Solving & CFD 62 September 18, 2017 06:45
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 20:16
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
