Importing CFD solution data in CFD POST
ANSYS CFD POST is experiencing an error while loading CFD solution data exported in CGNS format from ANSYS Fluent. Did anybody face similar problems? Were you able to find any solution for the same?
What is the error? Also why not import Fluent .cas and .dat files into CFD-Post directly as I think it can do this?
The cdat file doesn't allow me to directly generate the surface streamlines on the desired boundaries. I have to create a velocity iso-surface of minimum magnitude for the same. With CGNS files surface streamlines can be plotted without the requirement of a velocity isosurface.
