How to increase number of elements in a mesh by 1.5 times? |
March 8, 2020, 06:01 |
Aarib Irfan
Rep Power: 6 |
I am trying to test the effect of grid senstivity on Fluent. I have a .msh fluent 3D mesh file. I need to increase the number of elements in mesh by 1.5 times and then compute the solution and then decrease the number of elements 0.5 times and then compute the solution. I can't figure out any way to do this. Can someone pleaseeee help me
March 8, 2020, 07:06 |
Gert-Jan
Rep Power: 27 |
You have to go back to the software package that generated the mesh.
March 8, 2020, 07:14 |
Aarib Irfan
Rep Power: 6 |
I don't know which software generated the mesh. We are given .msh .cas and .dat files only
March 8, 2020, 07:20 |
Gert-Jan
Rep Power: 27 |
Better ask for a geometry file and build something new from there.
Alternatively, you can try to import the mesh in ICEM. Delete the volume elements and build a coarse, medium and fine grid from the remaining surface elements. Or try mesh adaption in Fluent. But that will only refine the mesh. |
ansys, fluent, icem 16.2, mesh 3d |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
[Other] Equal decomposition of cylindrical fluid domain | Sean95 | OpenFOAM Meshing & Mesh Conversion | 3 | February 12, 2019 03:34 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
