[ICEM] Periodic boundaries in two directions
Old   April 27, 2010, 10:12
Default [ICEM] Periodic boundaries in two directions
JP
jphastings is on a distinguished road
I'm having difficulty setting up translational periodic boundaries in ICEM v12.
I've modeled a simple 10x10x10 unit cube in ICEM. If you number the sides as if it were a dice:
  • Face 1 has a small square (2x2 units) in the centre of it, acting as an inlet
  • Face 6 is an outlet
I now need to set up the periodic conditions (I don't know how to do this)
  • The remaining opposite faces should be periodic, so that fluid impinging on face 3 should continue out of face 4 and fluid going into face 5 comes out of face 2 etc.
The tutorials I can find for ICEM show how to make models periodic in one plane (by setting Mesh > Global Mesh Setup > Set up periodicity > Define Periodicity, Translational periodic, Offset: 0 10 0) but I can't convince ICEM to do this in two directions, nor can I figure out how to export this periodicity properly to Fluent!
Does anyone have any suggestions?
jphastings is offline   Reply With Quote
Old   April 27, 2010, 16:09
Default One direction only, but can work around to get more.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Right, ICEM CFD doesn't currently support periodicity in two directions, at least not directly.
You can get around this by copying the surface mesh from one side to the other, replacing the existing surface mesh and then performing "make consistent" or simply remeshing the volume. This works easiest if the edge params were the same at the periodic corners...
We are looking to fix this soon with a "match control" that would allow matching mesh in any direction. This is in Workbench Meshing now, but does not yet support dual periodicity if it shares an edge (as it would in your case). We should improve match edges in WB to handle this soon also.
PSYMN is offline   Reply With Quote
Old   November 5, 2011, 18:07
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
I realize this is a bit of an old thread, but this very relevant to what I am trying to do right now. I have created a mesh, copied the desired surface mesh to the face that I want to be periodic. The problem is that I cannot figure out how to "make consistent". I have tried, but it ends up moving the nodes on the periodic face. How can I prevent it from moving these nodes? The other problem is that when I try to make consistent I end up with some problems where there seems to be missing volumes or holes in the face mesh. Any help would be greatly appreciated.
cdegroot is offline   Reply With Quote
Old   January 14, 2022, 06:06
Fabio Porcari
fabp70 is on a distinguished road
Hello.
I would like to know if now it is possible to apply the periodicity in 2 directions and how. My problem is very similar to the one explained above. I'm trying to apply the periodicity in the 2 directions without any success (I am running ICEM CFD 19.1).
Thank you,
Fabio
fabp70 is offline   Reply With Quote
icem, periodic boundary
periodic boundaries Mary FLUENT 27 January 6, 2021 01:54
CGNS import in fluent - periodic boundaries. Bjarne Børresen FLUENT 2 April 25, 2013 11:12
Why can't I make the boundaries periodic? Alina FLUENT 5 April 12, 2012 14:06
periodic boundaries - flow through a net PK FLUENT 0 July 12, 2007 11:58
Periodic Boundaries in GAMBIT!! swetha FLUENT 1 November 26, 2006 22:02
