problem regarding velodicity expression error |
February 23, 2020, 02:23 |
Rep Power: 6 |
respected members of forum
i have perusing a problem regarding velocity in ansys fluent .there is an error as i mention below my expression is 44[m/s]*(y/10[m/s])**0.133 error:Incorrect expression unit. Expression Unit [m s^-0.867], Required Unit [m s^-1] i have lots of problem regarding this.please guide me about this |
February 25, 2020, 04:05 |
Units
Change 10[m/s] to 10[m]. 10 might be value of velocity but the numbers do not care. [m s^-1] multiplied by [s^0.133] is leading to the incorrect units.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
March 23, 2020, 01:38 |
Rep Power: 6 |
Thank you so much for replying me
heartily thanks to you sir............for guding me i have follow ur guidence which helps me a lot and also thanks to cfd online forum |
velocity expression error |
Display Modes | |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 04:53 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 20:16 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
