March 21, 2017, 06:45 |
unknown Error
Prince Hossain
Rep Power: 9 |
** FATAL ** CP = 1.248 TIME= 17:38:49
While 1 GPU devices have been detected on this machine, no supported GPU devices have been detected. Only Tesla-series or Quadro 6000/K5000/K6000 GPU devices are supported. Please verify that a supported GPU device is installed on this machine or rerun without using the -acc command line option. ************************************************** ********************** The above error is non-recoverable by ANSYS ANSYS run terminated by the indicated error Current data base saved if possible. How can i solve this problem |
March 21, 2017, 08:56 |
Rep Power: 18 |
Use a machine with a supported GPU.
October 31, 2019, 04:45 |
cem toker
October 31, 2019, 10:38 |
Erik
Rep Power: 23 |
GTX1050 is not a supported GPU either.
However, I believe there is a way to make it run anyways. Set an environmental variable: ANSGPU_OVERRIDE=1 You may have to reboot for this to take effect. Then it may work regardless, however, the performance of that GPU may not be too great. |
November 5, 2019, 13:58 |
Alex
Rep Power: 46 |
Alternative solution: don't try to use GPU acceleration
Didn't know that you could force Ansys mechanical to use non-whitelisted GPUs. Is that a new feature, or did I fail to find it for several years? |
November 5, 2019, 15:29 |
Erik
Rep Power: 23 |
I think it is an undocumented feature. I found it a long time ago on some forum, and people said it worked after trying it. I never tried it myself though, as I doubt I would see much gain in performance, if any, due to the horrible double precision performance of most gaming cards, or cards not specifically designed for GPU computing. Heck, even the old Tesla cards were not too great if I recall. And their performance was very problem type dependent, and problem size dependent due to their limited RAM.
July 22, 2020, 05:49 |
#7 | |
Rep Power: 18 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 20:16 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
