Using STL files in Ansys Post
Old   February 23, 2021, 11:28
Default Using STL files in Ansys Post
nima103 is on a distinguished road
Hello every one,
I am trying to create temperature or velocity contours on a curved STL file that I import into ansys post as STL with ASCII format by inserting it as a "User Surface"
Although I import and visualize the STL file in ANSYS Post, I can not use the user surface to create contours. Ansys Post can create a legend for the contour that I want but it does not show anything else on the screen.
Any ideas are appreciated.
nima103 is offline   Reply With Quote
Old   February 24, 2021, 04:20
Originally Posted by nima103 View Post
Hello every one,
I found out.
The STL file should match in dimension only the Domain that you want to post process on. Then under the tab in user surface, you should change constant to variable and select the variable you want.
cheers
Old   July 19, 2022, 02:56
Bineet Mehra
bineet_aero is on a distinguished road
hi thanks .
i have almost same issue. for a pipe flow, it shows almost 0 velocity on the stl i imported .
thanks in advance for your help
bineet_aero is offline   Reply With Quote
Blender: generate stl files student666 OpenFOAM Pre-Processing 0 June 6, 2017 02:45
Post-processing star ccm+ results in Ansys CFD Post sidharath STAR-CCM+ 4 April 10, 2017 11:49
OpenFOAm solver, ANSYS post processing achinta OpenFOAM 3 May 13, 2010 02:54
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
Converting ANSYS CFX files to Fluent files Martin S. Rasmussen FLUENT 3 January 30, 2007 15:08
