Circumferential axial average for 3-D Pipe
Old   August 24, 2020, 11:38
Default Circumferential axial average for 3-D Pipe
AnthonyBowers
AnthonyBowers is on a distinguished road
I am in serious need of guidance or help. I've been working on trying to obtain the cross-sectional area average along the axial distance of the 3-D pipe. My variables of interest are Interfacial-|Area-Concentration, Volume fraction and Mass fraction.. etc. I used CFD-Post and heard of a way to record an action. However, the coding is beyond my capability. Please aid me in my research and understanding of CFD.
Thanks
AnthonyBowers is offline   Reply With Quote
Old   August 25, 2020, 03:18
M
AtoHM is on a distinguished road
I am afraid you will have to script that on your own. Allow yourself some time to test and figure out how the scripting works, it will benefit your future work in CFD, I promise.
Normally you would go and create a state, in your case with a plane. You better save it as state file, you might want to reuse it later. Then how to get the values: I think there are several ways, I once did something similar with a table. As you will need to script from here on, you start recording a session. Once recording is on, create the table and put your values you desire in there, preferably in the first row. Once you have the values, go back to the viewer and shift your plane by the step size you desire. Stop recording.
Now all you need to do is to figure out how a loop works and just write values to the table -> shift plane -> next step -> repeat.
Good luck.
AtoHM is offline   Reply With Quote
Old   August 25, 2020, 08:14
AnthonyBowers
Do you know of any documentation source for CFD-post syntax?
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
What Is The Accurate and Best Way to Plot Average Outlet Temperature of a Pipe? Shomaz ul Haq CFX 5 September 10, 2017 08:19
ANSYS 16.1 Workbench - Cooling Heat Source through Pipe Ninhalem ANSYS 1 July 26, 2015 20:05
Simulations of axial mixing of liquids in a long horizontal pipe ensmn FLUENT 0 January 9, 2015 12:01
axial velocity in bend pipe with adverse pressure gradient liguifan OpenFOAM 0 July 24, 2011 06:56
