September 16, 2020, 03:49 |
Infrared radiation and gas absorption
Ananya
Rep Power: 5 |
I am trying to model the following scenario: I have a silicon volume filled with CO2. Also, I have an IR emitter (which contains a heater, that heats up and emit IR radiation). The silicon has IR transmissivity of about 60%. So I would assume 60% IR intensity in the volume. Once the IR is in the volume, I want to model -
Fig: A rough model of the scenario explained above Thanks |
September 20, 2020, 11:14 |
#2 | |
Rep Power: 10 |
Hi, I can't answer your second question but for your first one, you could just add a simple heat flux boundary condition. You can be more detailed by filling up the wall thickness box as well as defining the material properties correctly. You can also attempt to define the heat flux absorption and internal emissivity of the material as a function of material temperature in Fluent. I believe this would give the most accurate results. |
September 21, 2020, 06:11 |
Ananya
Rep Power: 5 |
September 22, 2020, 11:20 |
#4 | ||
Rep Power: 10 |
I suppose it really depends on how detailed you really wanna go. If you wanna model the absorption thoroughly and transiently, then you may need to model the silicone walls and have a linear heat input source term as you travel through the silicone while having your 60% remaining IR radiation applied into the fluid domain. Quote:
I'm also not quite sure exactly what "Diffuse fraction" is supposed to mean. An explanation can be found here but I don't understand it either. here |
September 23, 2020, 02:35 |
#5 | |
Ananya
Rep Power: 5 |
Yes, material absorption is an important parameter and it can be defined with the help of material properties.
Using the "semi-transparent" BC, one will have the absorbed radiation on the other side of the wall (in this case, towards the inner gas volume), if one defines appropriate material properties (i.e. absorption coefficient, scattering coefficient etc.) and wall boundary conditions (i.e. external emissivity, external radiation temperature, internal emissivity and material thickness etc.) Regarding "Diffuse fraction", I went through the thread you have mentioned. Additionally, one can also have a look here for a more clear explanation. From my understanding, it's used on the case of solar radiation modelling, to account for diffuse radiation. Otherwise, it can be set to 0. Check here Last edited by fluent_noob; September 23, 2020 at 05:16. |
September 23, 2020, 08:08 |
Rep Power: 10 |
I see, then there is no need to apply a source term / heat flux to the wall then.
So the diffuse fraction is the fraction of energy that is reflected away from the surface, while the specular fraction is the fraction of energy that is refracted in the material and transmitted through. |
September 23, 2020, 08:15 |
#7 | ||
Ananya
Rep Power: 5 |
That seems to be the case |
September 24, 2020, 08:19 |
Ananya
Rep Power: 5 |
Apparently, I was incorrect. After some more reading (Lec-5 Radiation Heat Transfer, Heat Transfer modelling using ANSYS Fluent), I came across the concept that the fundamental difference between both diffuse and specular reflections is their nature. Please see the attached images from the above mentioned text, to get a more clear idea of types of surfaces, in addition to different reflections. |
September 25, 2020, 10:19 |
#9 | |
Rep Power: 10 |
I see, thanks for the update and clarification. I learned a lot from this thread even though you were the one asking for help hahaha |
#absorption, #fluent #infrared, #radiation |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
